Brake line rubbing
TSB and squeek in front drivers side portion of cab/dash
Are the door hinges adjustable?
Went to check the front brakes and the rt/frt br/line is rubbing on the upper arm. There was a post a while back on how to move/fix this dangerous :mad: :mad: DC oversight. I tried the search and came up empty,anyhelp:confused: :confused:
brakeline rubbing
shendren,I finally put a signature below.
I took a piece of 3/8 power steering hose 5" long and split it lengthwise. I wrapped it around tne brakeline and secured it with zipties:--) :--) . DC should cover this IMHO. :mad: :mad:
brake line
Went out and looked at our truck after reading your post. Right front line: I don't see how it could ever get into anything, But left front line was only 1/32" from coil spring and had been bumping on it. :( :rolleyes: can't believe they built it that way. Thanks for sharing. :)
