Living in & driving the mountains of Colorado can be hard on brakes. Towing compounds the problem. We have a 2200' climb getting home from Fort Collins. The last major climb is a 500' climb over about 2 miles. One particular grade is very steep, on a dirt road & has a 30 mph corner at the bottom which really eats up brakes. I went thru my first set of OEM pads in 35K miles. The second set was semi-mets which lasted less than 40K when the left front caliper decided to stick & ate up the left pads & warped the rotor badly.
At that point I decided to quit screwin' around w/ stock stuff. A couple of panic stops on the highway & some fading brakes on longs hills convinced me to go aftermarket. After quite a bit of research I went w/
Egr Perfomance Inc carbon/kevlar pads, blueprinted rotors & gas slotted rotors on the front. What a huge difference! No more fading on the long, steep hills. No more wondering if I'm gonna run over the econobox which pulled in front of me & then decided to stop suddenly. After 70K miles on the front brakes, the wear is minimal & the performance is fantastic.
This last winter one of the stock rear calipers decided to begin sticking. I knew then I'd go w/ EGR's stuff on the rear as well. We had a ~1500 mile trip planned for June towing our travel trailer over 15 passes & divides in Colorado & Wyoming & I knew I didn't want to do that w/ marginal or stock rear brakes. So the first of June I did the rears w/ the EGRs as well. We had a great trip. I'd also installed a Banks Brake for the long drops off the passes, but when someone pulls in front of you b/c your're pulling a TT, the EGR brakes took all the panic out.
Highly, highly recommended.
FWIW, our trip took us over Monarch Pass both directions & over Red Mountain/Molas/Coalbank. Those familiar w/ those roads know that w/ poor brakes those passes can be more than butt-puckering, to the point of being dangerous. The southbound lane of Red Mountain has places where the white outside line is bordered only by a +500' drop--there is no shoulder. In a couple places we went by the white line had disappeared as well over the precipice.
Let's just say my wife didn't want to do that road again very soon.
