I have an 04 3500 quad cab dually that pulls a heavy trailer..... This truck works 80% loaded... We use the exhaust brake all the time... . The truck now has 95K miles. .
We just pulled an inspection of the brakes... I really expected to change the pads... . all 4 inner pads were at about 40% of new thickness and the outer pad was closer to 55% of new thickness... ... .
Frankly we were amazed that we had that much left... as the trailer often goes to 18-20K... . However the new trailer has power disc brakes... a wonderful feature... . Thought we'd share that with the group. .
BTW - the lift pump failed and took out the CP3 pump about 5K miles ago and after a melt down with the dealer over some issues they picked up(DC that is) the cost of the repair.....
So we'll hit the 100K mark with one full set of tires... . at 65K, Lube Oil Service every 6-7K and 2 fuel filters.....
For the second 100 K were going to install a helper lift pump, and chase down a vibration under heavy load... . either a transmission bearing or a pinion bearing I'm sure... .
Jim
Jim
