So I have now replaced the hard lines from the MC to the axles and the rubber lines with braided stainless. New calipers on the front, rear wheel cylinders are not leaking. New hydroboost unit, new MC, new proportioning valve.
Pedal is firm/hard with engine off. Soon as it is running the pedal goes to the floor with little effort. Bled the system both forwards and back with vacuum bleeder. Bled all the fittings from MC to PRO, PRO to ABS manually.
Rear wheel ABS only. No rear load sensing valve. 1999 2500 4wd.
Been fiddling with this for weeks and either going to burn the truck or sell it.
Any ideas?
Any ideas?
