2nd Gen Non-Engine/Transmission brake problems
I replaced the passenger side caliper a year or 2 ago and today found that the pads on that side are worn down while the other side was only 20 or 30% worn. Do you suspect the drivers side caliper is not squeezing the rotor and needs replaced? The truck brakes straight with no pull to one side.
your calipers are most likely the problem. I never just change one side. To do it right try this. Go to Napa and get rebuilt calipers, Ceram-X brakes, and the slotted, cross drilled rotors. Won't cost you too much and your brakes will be right. Oh, also adjust the rear brakes
