My truck has a bad shake when I go to stop. The right front caliber "wiggles" and one of the rubber bushings works out after a short time. I checked the rotor and the pads- everything seemed fine. Also, my back brakes are way to tight. On loose roads, the backs will lock up way before the fronts. I let loosened the rear adjusters and after a week or 2, they were tight again. What do you guys think I should check next?
