I have a 97 with that load height proportioning valve and nearly 100,000 on the odometer and the original rear brake shoes. I think I need to either try upscaling the wheel cylinders but first I'd like to try bypassing that valve. Does anyone remember where they posted instructions and the part number for the replacement hose? Thank you... . Also an appropriate # for an upgraded wheel cylinder if I decided to go that route would be nice and the consequenses of each modification.
I do have overloads on this truck as well as the rear stabilizer bar. I run 80% of the time with 500 or 600 lbs in the bed. Thanks... .
