I have read numerous posts regarding brake pull on this and other sites, but have yet to discover a smoking gun as to the cause. I have replaced the calipers (loaded NAPA) twice, replaced rotors (NAPA), rear drums turned to insure they are concentric, rear shoes (NAPA), front brake hoses (Mopar) and rear wheel cylinders (NAPA GM 1-Ton), and the truck still pulls left. The problem seems to be temperature sensitive. The truck will stop straight when cold and after several braking attempts the pull returns. I thought the problem might be in the suspension as I've installed a new 2003 style track bar and DSS, but when one adds the temperature sensitivity back into the equation one must rule this out. I've even switched the front tires from side to side to make sure I didn't have a tire not to spec. (Really grasping). Truck has been aligned and tracks straight on all road surfaces until brakes are applied. Any ideas would be greatly appreciated. HELP!
