I've got a 2001. 5 - 73,000 miles. About a month ago, I bled the brake system out since the fluid was looking pretty bad. Since then, the pedal has been a **little** soft - I think I have a small bubble but nothing that's really concerning. I'm about due for brakes, but they still work OK with no pulling, etc.
Yesterday, I'm on the way home, coming up to a stop sign. Hit the brakes, abut 25% and they started to work, then the pedal went to the floor. I released the pedal, pumped it again and the brakes worked fine, with good pedal and no fade. I thought that maybe I hit a slick spot on the road and maybe the antilocks got confused..... until it happened twice more on the way home. The last time I was hitting them pretty hard, since I was trying to get it to repeat. This time when it happened, my slight sponginess disappeared, and I got firmer pedal.
When I got home I took a close look at the whole system, fluid level is good, could not find any leaks.
Road tested it again this morning, and it seemed to work OK. No pulling, fading etc.
The pedal seems to pump up alright with the engine off. It's not as firm as I would like it, but to be honest with you I never paid attention to it before so I'm not sure if it's OK or not.
One idea that I thought of was that the air bubble I suspected was in the system worked it's way out of the master cylinder. But I wouldn't think that would happen three times. I know that the power steering system is integrated into the brakes somehow, so I checked that fluid, level is OK.
So - any ideas?
So - any ideas?
