In fall of 07, right after I bought my truck, I put brake pads on the rear. I didn't have the pads spread far enough on the passenger side and cut through the protective cups in the ends of the pistons.
In may of 08, I was headed home, getting ready to start on a 2. 5 hour trip, and that same corner had siezed. One of the pistons had crushed and turned just enough to hold the pads in and heat everything up nice and dangerous like.
I replaced the caliper with a NAPA unit. It has driven fine for almost exactly one year. It's doing the same thing, only it will release this time. When I know it's doing it, i'm usually backing out of a parking space. I'm in reverse when I notice it.
I drove it 150 miles over the weekend, it was fine when I started out, and when I got off the interstate and onto the off ramp, when I stopped, I could smell it burning. I stopped and walked around touching the wheels. It was smoking pretty good.
I'm thinking I have a collapsed line. I can't think of another mechanism that would stick and release intermittantly.
Am I on the right track or could it be something else? I doubt very seriously that the truck has ABS. I just haven't seen it, fealt it or noticed it under the truck and it isn't in the engine compartment where i'd expect it. I'm also toying with the idea that the parking brake is at fault.
Thanks
Thanks
