A while back I discovered a bad front caliper on my CTD Ramcharger (Pulling hard to the right when braking). I replaced both fornt calipers and pads(Rotors were o. k). and rebled. A few weeks later, I decided to check on them and noticed that the "shims" on the inside, left front brake had slid out from under the pad and started to "curl" up. I took it back apart. Removed the shims and added a new one. Reinstalled everything, borrowed a power bleeder from the nieghbor and bled them really well.
NOW, the left front brake makes a clicking/Popping noise when braking. Seems to brake well and isn't pulling, but the noise can't bee good. Any ideas??
Thanks!
Andrew
Thanks!
Andrew
