FYI While crawling around today for a quick visual inspection I found a frayed brake line. The passenger front line has been rubbing on the lower control arm. The old line was nearly gone. I'm running stock rims with 265's. After replacing with braided stainless steel line I found out the bleed screw was very plugged. I bought four new ones just to be sure. With my luck it's probably only me.
