2nd Gen Non-Engine/Transmission brake wiring
Engine/Transmission (1998.5 - 2002) broke dip stick
Engine/Transmission (1998.5 - 2002) fuel pressure vp44?
Hello,where does the blue wire (brakes) from a trailer brake controller splice in to my factory trailer plug harness. I have a feed wire to the outlet on the hitch-plug but cant track it under the hood. Thanks for any help
Are you looking for 12v to actuate the brakes? There is a junction (on my 96 at least), on the bottom right of the brake booster that runs out to the rear tailights. There is a white/brown stripe wire that feeds the rear tailights, you can tap a low draw feed from that. Other than that, I dunno... havent wired an external brake controller in yet. . heh
good luck
Jerry
