The brake and anti-lock warning lights came on last night. The front (smaller) reservoir of the master cylinder was low. I filled it up and the light went out with a few pedal pushes. After a few more brake applications both lights are back on. The fluid level did not go down in the front or rear reservoirs. So I have a hydraulic problem, but I am not sure where.
I would like to get Red ready for the next 200k. I have read enough old posts to feel like I know what some of the issues are, but I could use some help with the details. Questions:
1. Any idea what the likely leak or problem point is? I looked for wet areas around the lines, calipers and wheel cylinders, and did not see a source for a few ounces of fluid that are missing. I will take wheels off and do a more thorough inspection tomorrow.
2. I would like to get rid of the RWAL. I located the unit on the driver's side frame rail. From the previous posts, I have down to get two Inverted Flare fittings to connect the two brake lines: a Weatherhead 252x3 female coupling (for the 3/16" line), and a Weatherhead 202x3 male connector for the 1/8" line.
3. With over 200k on the clock, is it time for a master cylinder and booster? From the previous posts, it looks like replacing both at the same time is the way to go, either Raybestos or Bendix.
4. I have looked for a source for stainless brake lines, without any luck. Does anyone know of a manufacturer or retailer? Are stainless lines a worthwhile addition?
I apologize for the long post, but I wanted to get everything in order before I take it apart. I appreciate any help or thoughts you can offer.
-Richard
-Richard
