Ok, I had the brakes NOT work at one stop tonight. Luckly, I was in the middle of an empty parking lot. The pedal went to the floor when I hit the brakes. Stooed with the emegerncy brakes. I got out the flashlite and crawled around looking to see if there were any leaks. None. So I checked the fluid level in the resivor, it was about right, BUT there was gray blobs floating in it. There were maybe 8 blobs in it. They are completly insoluable in brake fluid. They are a dark grey. And they are very sticky. My guess on what happened is that the seal in the master brake cylinder is dying, and this is the grease that is on the other side of the seal to lube things. It did work every time I tried it after that. But if I held down the brakes, the pedal would slowly go to the floor. I drove the 20 miles home on engine braking so I didnt have to worry about if they worked or not.
If you have any other ideas on what might cause this, price of a master cylinder (vacuume), or some other usefull piece of knowledge, let me know.
1996 2500, 4x4, 5 speed
-- email address removed -- Great Lakes TDR
PURDUE STUDENT
GO BOILERS
PURDUE STUDENT
GO BOILERS
