I've done the searches and this doesn't appear to have come up before so here goes...
A couple of days ago I leave my house in the morning, drive about 5 miles in stop and go rural roads and I notice that it's like something is holding the truck back. Usually you let off the brake pedal and the truck starts to move forward pretty easily. Not so - and it started getting worse. I turned around and headed home and it progressively got worse until I felt like I was having to power my way home, brakes locked the entire way.
I let everything cool down (front wheels were very hot) and tried again. This time it took just about all the power the Cummins could muster just to back up. Laying rubber almost the entire time in reverse! Eventuall I just started going forward again and made it home - powering through the brakes the entire time.
I took off the master cylinder today, drained the resevoir and used a screwdriver to depress the plunger. Brake fluid comes out easily through the brake line holes. I put 2 fingers over the holes and released the plunger and I felt a vacuum. My friends don't think it's the master cylinder. Sitting in the cab, I depress the brake pedal, the plunger of the Hydro Booster comes out. When I release the pedal it moves back in - easily.
What could it be? I do have SS Brake lines. I know that's not a guaranty against an internal collapse but it's better than the usual rubber lines.
Any ideas are appreciated.
