OK, so here are the deets. 2001 , 3500, stick, hydroboost brakes, 4x4, 327,000 miles, original/stock under the hood. The power steering system has been leaking for quite awhile now, and I am in the process of getting the parts to change it all out IE; gearbox, pump, hoses. Haven't had any problems other than having to add steering fluid all the time. I jump in the truck Sunday ,after moving it around my property earlier without incident, to run a motorcycle over to my friend. I top off the steering fluid and back down the driveway. I turn towards the street, and it won't move forward. Check the transfer case, not jammed in 4 wheel drive. Pop the hood, and everything appears fine, but I hear a popping / creaking sound from the brakes. Shut the engine off, and it sounds like pressure being relieved, then a pop like a check valve releasing. Get in, start it up, truck moves OK, then I apply the brakes. The brakes lock up, and won't release until the engine is off, and the pressure lowers. The (feed ?) line from the pump is very hot. Air in the system, something jamming a valve, new booster needed? This is my first hydroboost braking system, so I am not sure what all is going on here.
Tried the search, but didn't find this problem.
Thanks in advance.
Thanks in advance.
