Brakes Locking Up
pcm problems on the ol 93
Fuel bleed down
Donovan- no biggie on the mistake; I've made plenty of them through the years and been quickly corrected.
The pumps are different from the nonIc to the Intercooled trucks. The early ones had a cam inside the housing that had 2 pushrods that drive the 2 UFO looking pods to make the vacuum. Later ones have a vane style pump that makes the vacuum. No cam, no pods
DP
DVolk said:
Ok i guess im wrong my pupmp on my 92 has 2 lines .
but tell me this one , other than some "Gobblin "living in my trucks hood area
My truck had some brake issues and i added powersteering fluid and it went away , the brake resevor was full , i do loose some fluid during the summer months , the brake lid gasket gets weired out ,
But i dont have a littel canister like on my 90 motor in my Suburban im
converting .
This what i think is happening and its still a powersteering lowfluid issue ,
Is that the vaccume pump needs the fluid in the system , since i dont think its a sealed unit , it happend the one time i was low on fluid
check it out for fluid or air in the system
only other possibility is the plunger sticking on the antilock crap
Donovan , my parial mistake sorry
Your 92' vacuum pump has an oil feed line unlike the earlier twin POD canister type pumps. There is a braided hose behind the vacuum pump that feeds engine oil to the vacuum pump. The power steering and steering gearbox are separate system. Your addition of fluid and braking issue clearing up could be a coincidence since these systems are separate. Do you have Factory Service Manuals for the year models you own? I have read several of your posts here and on the conversion forum and I think you would benefit greatly from the FSM's. I think they are well worth the money even at full retail pricing. If you keep an eye on Ebay you can get a better price on them.
Brakes Locking Up
Only factory book i have is the mopar race books if any one has one or sees them cheap ill take them .
I got NH cummins books , NTC , and N14 books and a few books that were jokes on the 5. 9
I dont know it all, but i try to be informed
Plus i have other deisel toys
anouther 69 peterbilt with a 335, and 13spd main and 4spd aux
52 auto car4x3 trans 220cummins
John deere 4020 farm tractor
massey ferguson MF 175 with a a4236 perkins
Kubota B5100E needs a transmission , any body got one ?????
I do know the old single and double disc pumps
Fixed
I got around to fix my brake issues today. Wheel cylinder was leaking on the drivers side and the brake pads on the passenger side wer severly crack. Anyway I appreciate everones help and I am thrilled to have good brakes again. :)
Aren't these drum Brakes?
Fussy?
The "pad" that is held to the "table" is called the "block"
If nothing more, this thread has provided some real entertainment.
There is a balancing valve somewhere related to the booster. The best thing to do is replace the whole booster assembly. Its not to difficult nor overly expensive.
