I bought this little 5vr last fall... brakes have been less than strong since we got it out this spring. I've literally been running with my controller almost full on to get any comfy stopping power out of it... when I bought it last fall, I could easily slide the wheels when I applied the brakes manually. So that got me thinking...
I just had the wheels off it last month for new bearings, brakes and magnets were good. I checked the adjustment, everything looked good (keep in mind it only had 150 miles on it since I brought it home). And it had just been through inspection (once before I got it, and once again this spring). I also replaced the half-worn-through trailer-to-truck wiring at that time with a new one... everything was soldered.
I remembered there being a ton of scotch-locs under it on the brakes, and I hate them with a passion... they tend to corrode and they sometimes don't fully contact the wires. So I decide today to start redoing the brake wiring. It has been spliced several times, so I simply bought new wire. When done, I will have four splices that will all be soldered.
I start following the routing of the wiring, paying particular attention to that which follows through the axles, and find that one brake was never hooked up. Not damaged, just never hooked up! I've been stopping with THREE brakes!
I have EIGHT connections using scotch-locs, of which all of them are exhibiting signs of corrosion. I do some resistance testing of those connectors... I have SIGNIFICANT resistance from the trailer to the brakes, no wonder I've lost significant braking power.
And to boot, the wiring was practically falling from the frame...
Now my question is, and I think I know the answer, are the magnets polarized? Do they have a positive and negative lead, or are they non-polarized? I don't think they are, or the wires would be well marked...
