"94 3500 TD 5 speed - The right rear brake seems to grab (when applying the brakes in my gravel driveway the right rear tires side). I have put new brake pads/shoes all the way around the truck and it still happens. I have backed off on the adjuster and it seem to help for a couple of days but then it started again. Maybe the left side is not working or maybe there is some sort of equalizer that is malfunctioning. The problem is I haven't had a job in some time now and can't afford to start replacing everthing hoping that I run across the problem. I need help in diagnosing the problem.
Thanks
Thanks
