Heads Up.
There is a guy at work here who has a Chevy 2500 with a BrakeSmart controller who was having problems with the brakes going to full lock at times when he was applying light brake force. Turns out that the BrakeSmart pressure sensor wiring is susceptible to RF interference from CB radios and puts the controller into "panic mode". This only happens if you are transmitting on the CB while braking. BrakeSmart has confirmed the problem, and is working on a fix.
