Engine/Transmission (1994 - 1998) Braking Wobble
Engine/Transmission (1994 - 1998) Your smoke stained my paint!
Engine/Transmission (1994 - 1998) Did I get a deal?
Had a new problem start a couple of weeks agao, during braking I am getting a wobble in the frontend, it feels like one side of the tire is flat, (ha,ha) the wobble seems to be worse the harder I apply the brakes. I have recently checked the brakes, capilers,hubs, etc. I replaced the wheel bearings and this did not fix the problem. Any ideas?????
Warped rotors!
Keep those Caliper pins well lubed!
If the pins are even slightly corroded they will cause the brakes to drag.
Dragging brakes will cause the rotors to warp.
I have a solution if you are tired of lubing your caliper pins every 1000 miles.
PM me for details.
SFB
