I've got a few questions about pulling a trailer. I've pulled a few trailers before, but this is finally my own trailer and I have a few questions
The trailer is nothing fancy, it is 2 years old, tandem axle, 16' flatbed, bumper pull, it's got brakes on one axle, and it has the breakaway setup. I've got a Tekonsha Prodigy controller in the cab. My only real question is about the breakaway setup. The previous owner of the trailer had never used the setup, and disconnected one of the terminals on the battery. I figure since I've got the setup I should use it.
So, first off I want to check the battery:
Should it be 12 volts or 6? If the battery is not fully charged, is it alright to put a small battery charger on it?
What is the easiest way to test and make sure the setup will work?
Finally where should I attach the small cable that actually engages the setup should I lose the trailer. I was thinking to set it up so it is just a little tighter than the safety chains. That way if I lose the ball mount and not the safety chains the trailer will lock up. Or is it better to just attach it to the truck so it will only engage after the safety chains have been broken.
The truck/trailer combination that I will be pulling weighs about 7000 lbs.
If I left out some information let me know, and thanks for the advice.
