Since I can’t use the search feature, have to ask since this is scary! Last week—at the recommendation of a TDR member some time ago—I had a set of “Iron Claw” pads installed on my 94 TD. Noticeably superior to former pads. About 5 days later, while pulling into a parking lot, brake pedal slowly goes to the floor. . no brakes! Apparently neither front nor back as I was in idle and could not stop the truck. Had to use neutral and then reverse to do it (automatic tyranny of course).
Towed her to my mechanic’s garage and all worked fine! Road tested and all fine! Noticeable smell from the left front. No fluid loss. Current thinking is that the old (205k) fluid could not handle the additional heat generated by the high performance pads. Also will replace caliper and hose. Any other thoughts?? As usual appreciate the help of the TDR crew.
