Thing is, you WANT your brake fluid to absorb water. That is one of it's required purposes. It helps to keep the brake system from rusting from the inside.
The only problem with is that by and large, most people don't keep up with their brake system and flush it often enough (as in, most people NEVER flush the brake system).
The DOT 5 is synthetic and doesn't absorb water, it isn't compatible with the other fluids, and it doesn't have the same compression characteristics.
The DOT 5. 1 is NOT synthetic, but it has the same boiling points at DOT 5, both wet and dry. This is good stuff.
But the question of whether it's worth it or not, well, do you ride your brakes a LOT when hauling heavy?
You can actually find a good number of DOT 4 fluids on the market with almost the same boiling points that DOT 5 or 5. 1 has.
