Thanks Guys for the speedy reply. I looked at the sealsOriginally posted by ageorge
I agree with Holeshot, if the rear shoes especially are damp they will lock with minor pedal pressure. If the rear seals are depositing any EP90 on the shoes it will be very touchy.
Water entered my system from an improperly replaced master cylinder cover. (thanks to my local NYS inspection station) I did not pick up on this till many miles and rain days later. I still don't know what is causeing this front grab. Still under warranty but I hate having to bring in to don't give a damm mechanics at Dealers.Originally posted by ageorge
I have 78,000 miles on my 98, and have changed out the fluid once@ about 50,000. Don't know what you mean when you say you found water in the fluid. The fluid is very much like a sponge : it sucks up water and absorbs it into the brake fluid if the system is either left open or has a way for air to be introduced in the system. you have to be very careful how long the cover is off the master cyl. , cover it up as quick as you can.
Nope. No brake fluid on the rotors. They are clean. Just read that someone else has the same problem. On a dry day. Mine still grab on a dry day but its worse on a damp morning. Could be the wet road making the skid easier. Thanks everyone for adding there comments on this problem.Originally posted by Missouri Mule
Did you notice if you had brake fluid on your rotors? Almost any fluid will make them grab.
Never had water make brakes grab, usually had to ride brake after going thru large puddle to dry them out so they would be there when I needed to stop ( if you don't ride them a little when you step on brake to stop feels like you don't have brakes/as matter of fact you have very little breaking power).
Brake hoses could be collasping keeping pressure against front brakes, until they been used a few times. ( I know brakes hoses can cause calipers to stick but not certain when they do it, little use/ lot of use).
