Breakover springs function
More RPM
More RPM
What exactly is the Breakover Spring? What is its function? In checking with my service manual (one of my better xmas gifts) I noticed that mine is incorrect. I did change the adjustment rod this past summer and I just threw it on. I am now going outside to adjust to the proper setting but wondered what it does.
Thanks.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, RS9000, Tekonsha, Running boards, Lund Sunvisor & bug shield, Marker lights, Tonneau cover, Full cap, DynoMax, 5" Chrome tip, 16 cm Turbo, Isspro Boost, 23 lbs Boost empty, Oil Pressure Gauge, Pump Adj, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
I wondered too. It seems that it provides a little tolerance between the throttle linkage and beginning movement of the injector pump. If it did not have that your throttle would activating/effecting the pump all the time. Other than that I'm wondering too.
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
Watch your throttle linkage as you get someone to do a wot. [engine off of course] The break over is there to protect your pump, otherwise you would end up pulling on the shaft & wearing out the bushing in no time flat.
Piers, BD engine R&D
I did make my adjustments this past weekend. The little rod was starting to wear into the spring. I assumed that was what a Breakover spring did for its job, to save the pump. I seemed to have lost just a very little bit of my upper end but that is fine with me knowing that my pump will last that much longer. Now I just need to tune my TPS and it should be running super. Overdrive seems to lag sometimes going into it. I replaced it not very long ago but I never checked it then. Maybe I just need a shift kit to have it shift the way I would like it to. Have never adjusted the bands either but plan on doing that next filter change. This truck would continue to run forever if I just left it alone. But with the help of everyone on this forum, it is running better and better instead of just running. Thanks to all.
