Breather hose T-Case
ATF oils
1998 12 valve 5.9 cummins needs boost
Hello.
I have mounted the T-Case back at the truck. The breather hose for the T-Case was left at the truck, but now i see that it just laying loose on top of the Automatic transmission. In the end, it is a bent pipe with a bracket. Someone know were to mount? I do not want it fell down on the drive shaft, or get stuck in the gear stick levers, to the T-Case.
Thanks.
