I purchaced some headlights with higher wattages to replace my stock ones (one burnedout). After plugging the newones in I went for a spin up in the hills and was dissapionted that they wern't brighter!
At home I got out the fluke87 to see what the problem was. I read 9. 4volts between dim and ground.
Thinking how to fix this (way to much voltage drop). I bought two lighting relays,two 30amp circitbreakers,and a diode. I ran #12 wire to breaker then through relay to light. I used the old lighting wiring to control relays, placing diode between bright and dim wires so when I hit brights they all come on Oo. Oo.
What a difference!
This works great for off roading!
Happy bombing Eric
What a difference!
Happy bombing Eric
