The 1693 is a general fault coded. It just means that there is something wrong with the ECM or PCM. There should be some other codes. They just might not have been stored. Most likely problem is the vp-44. Usally when a lift pump dies, it takes out the injection pump(vp44). Do you have a fuel pressure gauge to check lift pump pressures? Can you crack an injector line or fuel line to see if fuel is being pumped? If you turn the key and bump the starter, without starting the engine, do you here the lift pump run?
