Engine/Transmission (1994 - 1998) Broke, Need New
Engine/Transmission (1998.5 - 2002) Lift Pump Relocation Questions
Engine/Transmission (1998.5 - 2002) truck wont start on its own
I finaly have my reason to get a full HTS trans. Friday night I was at the local dragstrip and made one pass at 13. 3 and then on my secand pass I broke the output shaft leaving the line. I have been wanting to get the whole transmission gone through and now I can. Has anyone else broken the output shaft on a 47RH transmission? We have not heard of anyone breaking one.
Chris
they have been broken before, from my understanding it can be a quick fix by simply dropping the OD unit and bolting a new one up. but a new trans is always sweet!
Ton's of guys have broken them.
at what boost level did you break it??
you can replace the output shaft in the OD unit, just need to drop the OD unit and pull it apart and replace the shaft, the stock O/P shafts are cheep, but you may want to up-grade it.
Scott
awesome Oo. chris wish I could of seen it happen sweet but you already know why I wasn't there first plugged injector then oil spraying out of the coolant overflow bottle but Link's injecotrs and dv's will seat you back in the seat I think I might have jason beat but got to fix it first.
You going billet all the way out just input and output like mine?
