Details here: TDR Privileges
OK, I just competed the Govenor Lever adujustment, and broke my banjo bolt buttoning things up... . Any suggestions on where to get one in the Stockton, Ca area, on this 3 day weekend... .
I have to head in to work, so I'll check around in town. . The authorized Cummins shop in town is closed, but maybe I can come up with something before Tuesday... .
Is it the same bolt that is used on the 24v engine? 12mm x 1. 5 pitch? Nine inches long (kidding)
If so, I have several.
You might also consider converting to -6 AN fittings. Put a new -6 female SAE end on your supply line and screw a Weber fitting (12mm/1. 5pitch x -6 m flare) into the pump.
