You broke what? I asked my buddy when he called me...
Apparently while backing up his trailer, he put it in first gear and let out the clutch suddenly while still moving backwards. He said the back u-joint twisted out of it's "u-bolt" and broke one of the "bolt hole ears" off of the rear axle input flange for the drive shaft!
Anybody else ever have this sort of thing happen?
Also, is there an easy way to get that input flange off of the rear axle? When I had to replace the pinion seal on my truck, I had to put on a great big puller, beat the snot out of it, then heat it and beat it some more, to get it off.
His truck is the same as mine... see signature...
