Engine/Transmission (1998.5 - 2002) Broken Slave?
Engine/Transmission (1994 - 1998) ATF for a DTT 47RH? ATF + 4 ok?
Engine/Transmission (1994 - 1998) timing tools, SP500 vs SPX 6860?
Ok, pretty sure the slave cylinder is the cylinder that actually pushes the clutch fork in, but the one up by the pedal that the clutch pedal rod pushes on broke out of its bracket a few days ago. I have a DD clutch, and upgraded the clutch hydraulics when I replaced the clutch. Has anyone else had this happen? Its really starting to make me #@$%!. I keep having to rig it with some JB Weld/Epoxy, and I hate riggin anything on my trucks, much less my 02 daily driver. This makes the third time I've had to re-JB Weld it in the last 2 weeks! I'm in Hazard, KY on rotations and can't get ahold of the fella that I purchased the hydraulics from. Needed to vent to some folks that understand the situation,
Thanks
James [><]
