RBridenbaugh
About 3/4 of the way through my 2,800 mile road trip (CA - OR - WA - ID - MT and back) with my slide-in camper I ended up breaking the right tie rod outer, by pulling the ball out of the socket. It wasn't on a bad USFS road and luckily I was only going about 10 mph when it happened. Also lucky that Condon, MT was only about 10 miles away, with only 4 miles on gravel, plus they had a flatbed that would hold my one ton with camper and a garage with equipment to change out the parts once they arrived the next day
Hard to steer with one wheel pointed out. Really very happy that this didn't happen at speed on any of the hundreds of abrupt construction/repair transitions on I-80 and I-580.
Truck had about 140k miles on it. Opted to replace most of the steering linkage as I'm going to Alaska next year and don't want to sit on the side of the road there. Other outer tierod end was also worn.
Is it typical to change out the steering linkage at about this mileage?
Any suggestions to replace other suspension / drive line parts as preventative maintenance, figuring that the tierods are early indicators. Ball joints are in specification (but the specs are wide) so I was planning on changing out those this fall.
