Can a broken transmission mount cause shifting problems ?
The last two days while shifting from 4th to 3rd once out of fourth I couldn't shift into third . Or any other gear .
Had to slow down before it would shift into gear. Sometimes double shifting helped or at least I thought it did. . Always seems to happen going into third, even from second to third. The clutch was replaced a year ago so I hope nothing is wrong there . Its been fine till now. I got under the truck and using a small pry bar was able to move the trans up and down alot.
