I had and 03 truck come into the shop the other week and after disassembly I found the rough running and noise to be caused by a dropped/ broken exhaust valve (#6 cylinder). I contacted the machine shop we deal with and was informed this apparently is quite common, and he had 10 (!!!) engines currently under repair for the same failure. Some engine were higher kilometers (200k+), and some were being subletted by dealers for repair under warranty. From what I was told, the heat in #6 is much higher due to the exhaust manifold design, and there is also an "unofficial" repair from Dodge; replace the stock manifold with an aftermarket design such as ATS or BD. I like to think I'm pretty up on the Cummins, but I've never heard of this before, and don't recall ever reading about this failure. Am I just out of the loop on this one? Or is this a new concern rearing its ugly head? My big concern is my own truck is just under 180k, and I'm not too keen on a wrecked motor from a dropped valve. Just want to hear from others and then decide if I roll the dice or if I should plan a head removal and valve replacement weekend.
