I just looked at my 95. There is a blue & orange wire. These both appeared to be about 4-5 inches then each one is "spliced" with what appears to be heat shrink. On the other side of the heat shrink, the orange is spliced into a red with a thin off white stripe. They are taped, and run down to right in front of the shock tower, and go into "split loom". The split loom is about 1",
"y's" off towards the fire wall, and up towards the engine. I looked in my service manual, but was unable to locate what they were for. Without cutting off all of the tape, and removing it from the split loom, I really can't
tell where it goes. Since the orange is spliced into a different color, hopefully
this will answer your question. Good luck.
Jim
