Bucking after injectors
P7100 conversion kit
What is up with all this blue smoke???
I finally installed my 370hp, oops I mean 365hp or less injectors earlier this week. Now my truck wants to buck a little when taking off in 2nd at near idle. Also, it wants to die instead of catching itself when starting cold. The idle speed is the same as before the injectors. I have the AFC adjusted according to the TST instructions. One of the throttle springs has been replaced with a stiffer one to cure a previous bucking, however, that happened under throttle. I am thinking that I need a little more no load fueling. What do you guys think?
Brian
97 2500 SLT 4x4, 5sp. , 4. 10 LSD 285/75, Isspro boost and pyro, TST #10, McLeod clutch, BD governor springs, 370hp injectors, TST AFC kit, HX40-16cm2 Majestic, Holcomb Air, BLH 4" exhaust, BD Remote Brake
