I have a 1995 reg cab 4wd 5 speed with 228,000 miles. I bought the truck two years ago, got a TDR membership soon after, and have been enjoying both. There is one small troublesome problem with the truck which I am about to explain, hoping that TDR will really prove its worth by helping me solve. The truck had a slight miss at idle to 1300 rpm, and above 2500 rpm would smoke clouds of white and flutter badly.
Against the advice of others and maybe my own better judgement, I bought it anyway. I'm glad I did, the truck has been great, but really want to get it running right.
A fuel filter helped the high rpm smoke problem, but it still does it somedays and sometimes runs fine(the weather?) Multiple fuel filters, testing the injectors twice, a new lift pump, checking the fuel precleaner, various fuel additives, a valve adjustment, and even backing off the aneroid and sliding the fuel plate wide open have not improved the first problem. (it did make a great running truck as far as power) My boost is about 25 and EGT about 1150 (before turbo) under load around 2400 rpm. My mechanic says I need to rebuild the fuel pump, but I want to be sure before I spend $2000!
The reason the miss/vibration at idle/low rpm is a problem, is that it transmits through the drivetrain under light throttle while gently cruising along, and quickly escalates into full scale bucking, which I'm sure would break something eventually. The odd thing is that under heavy throttle at any rpm it runs smooth as silk. (as only a Cummins will) It seems to me as though there would be some kind of broken spring in the governor or something. (I can do somewhat involved maintenance, etc. but major repairs are another story) I have been running the truck with the cat/muffler/ tailpipe removed since I was at a truck pull and wanted to make some noise. (don't tell my wife) With the more pronounced exhaust noise, I've noticed that when the missing is happening, it sounds as though the truck is running on one or two cylinders. The truck is still fine to drive if rpms are kept above 1500 under load, but I'm scared of what could happen if I let someone else drive it.
I've tried to be detailed so hopefully someone will recognize the problem, hopefully I didn't put you to sleep! Any help much appreciated!
