[Since there's so many posts under both topics]:
I'm still a little confused as to the symptoms described by some as "hesitation, stumble, bucking, miss, and shudder. " One minute it sounds like everyone is describing it coming from the motor (fuel related), and the next from the drivetrain.
Here's my story: Last night I was hauling my 30' gooseneck with a load of cows 650 miles one way. Coming east through New Mexico on I-40 out of Abq. , I set the cruise on 75 and had no troubles keeping speed up some serious grades. PE Comp was set 1st on 1x1 (max temp 1150), then set it to 3x3 and it ran better and a little cooler.
Then later, I disengaged the cruise and that's when I notice the, what I call the "Bucking" symptom when accelerating up moderate grades. I was on setting 2x2 at the time, and the symptom definitely lessened when I turned off the Comp. But, I could also tell I was running with less power (fuel). When it started, I first slowly accelerated, then I let off the throttle slowly until the symptom went away. I didn't try accelerating "all the way through it" like some have described, so I don't know if that would have helped. But, I did apply a little and it only worsened.
The best way I can describe my feeling, is that it felt like I was rolling on "egg-shaped" wheels in the rear. I don't think it felt like a "hesitation, stumble or engine miss" like some have said. To me, it felt more like axel wrap like when in soft dirt or snow. Like the torque was twisting the spring packs and axle, causing the "buck" and then exaggerated when more throttle (fuel) was applied, but decreased as I let off.
The outside temp. was in the 30's for the whole entire trip. I've noticed some describe cold weather (not warm) as a condition to the problem.
This is the first time I've had this problem at all. My last heavy haul was in warmer weather, and I didn't have a problem. And I never have/had it without a load. Either my problem is just starting, or the cold weather/heavy load combo. is a possible cause/condition of the this problem (even though I didn't have a problem in the biggest hills of NM with the cruise set on 75).
I wonder if it may be gear related? Someone said no 4. 10 posters have replied to this problem. Also, what are the commonalities: manuals vs. autos, 3/4 vs. 1 tons, overload springs vs. not any, 4x4's vs. 4x2's, etc... So basically, I'm as confused and p'od as the rest of you about this problem. Hope it gets figured out soon.
