David Wheeler
Unplugged this morning and fired her up. Even after being plugged in for 4 hours, "Wait to Start" stayed on for 15 seconds (10 degrees this morning). Gingerly drive the truck as normal waiting for operating temps. PS pump squalling like a cat, but that's normal on these cold mornings. Anyway, 5 miles down the road and the beast starts bucking and acting like it's out of fuel. Got stopped, idled fine. Tried to go again and around 1800-2000 rpm it starts bucking again. Eased out of the throttle and kept moving slowly. Started climbing a small hill and the view through the mirrors was a white wall of smoke!! Time to pull off! Again idled fine. Limped the truck to work at 25 mph on the shoulder of the road. Any faster and the bucking worsened. At lunch time went out see if warming in the sun may have helped the situation. No soap! Opened the hood, pulled the drain valve on the fuel filter canister and "woosh!!!!" Never heard that before! Sounded like someone opening a 32oz pop bottle. Took the top off the fuel filter and found nothing strange (no frozen matter or gel). Drained off some fuel (sorry, on the ground
) Replaced top and re-torqued. Fired it up, drove it down the road... ... no more problem! Now I wonder what gives?? Air in the fuel filter canister? If so, how did it get there? Changed fuel filter a week ago, primed before starting and all was fine. 1/8 tank of fuel..... too much air space for the cold?
Any experience that will explain this and possibly help someone else will be appreciated. Sorry for such a LONG post
David
David
