Kent Kuykendall
I have always had a bucking when under load with any type of fuel/timing adding divice. It was not evident unless towing trailers.
Here is what I have found.
With the smarty on fuel only I have no bucking.
When on timing settings and towing I have bucking.
So when I tow I set it on mild catcher and truck runs flawlessly.
Truck will also build more boost than with other non pump wire tapping devices that I have tried.
I first installed a Fass thinking that it may have a fuel delivery proplem. It did not cure any problems. However I think the truck runs quieter and smother.
So if you are on the fence with this type of problem the smarty took care of my problems. I can't say it will help yours but it did take care of mine. . Great product.
Kent
