OK folks:
When towing this weeking in North Georgia every time I got to a point where I had to give about half throttle to climb, the truck started to buck and it would get so bad I had to clutch the engine or I would broken something. It would do this in third and fourth. If I dropped into 2nd and ran about 2400 RPM it would pull without any problem.
Now when I run empty I have a slight "quiver" to the engine I cannot seem to find. The pump has been set-up by a Bosch mech. and he says it is fine. The only up-grade to the motor is 300 injectors. Could this cause the trouble? I have been told the govorner need a rebuild. Is this the trouble? I didn't have this problem till I broke the throttle rod. I replaced it and this started. . The only adjustment I see is the 5 inches from the ball joint and the frame bracket. Is there another adj. I don't see? The hopping feels like the petal is being pushed in and let go very quickly.
I can't tow like this but I don't know what to do.
Does anyone have any idea what is up with this pump?
Thanks;
Preston
96 3500, Black SLT, 5 speed, turbo diesel, , with US Gear overdrive, Rhino liner, Reese 15,000 lb. fifth wheel hitch, US Gear de-celarator exhaust brake, muffler elimination kit, Amsoil lub. , Mag-hytec rear cover, dual-remote by-pass filters, and Roadmaster Active system, AutoMeter Pyro & boost, Primeloc
Thanks;
Preston
