Well, picked up a new project this weekend - '96 extended cab longbed 4x4 2500 (913 pump). 5-speed already has the upgraded input shaft and dual disk clutch.
Aiming to build a puller on a budget for 2. 8 inducer class, and just curious what ideas you guys might have. Right now, I'm thinking:
Weld up the front and rear diffs
Gauges
Laser-cut DV's
4k gsk
370's
Hotter plate for the pump
Big single, HT3B/HX55/B2/H2 size
O-rings and studs
Light dremel porting on the head when I pull it
Traction bars
Cheap intake and straight exhaust
Street puller type cam (big as I can go without cutting pistons)
Any advice or other ideas to build power cheap? Know a place to get cheap turbos? (Seen 3B's rebuilt for $250-300 on ebay lately - not bad at all).
Thanks!
Chris
Gauges
Laser-cut DV's
4k gsk
370's
O-rings and studs
Traction bars
Thanks!
Chris
