The other day, a friend, who works on automotive A/C systems, noticed I had installed a piece of window screen across the front of my radiator, to keep the bugs off.
He suggested that I might want to consider removing it, due the the air restriction that it caused. He told me that the screen would probably not have been a problem in the days before Freon 134 systems, but the newer systems run at a much higher "head" pressures. Any additional air-flow restriction can increase these pressures quite a bit, and cause blown hoses, or worse.
To get an idea of how much air resistance the screen adds, he suggested taking a piece of screen and mounting it in a frame and holding it in front of you and see how far and fast you can run. Then try running the same distance without it. Either way would probably kill me, so I decided this was not a test I could use to verify his explaination.
I have seen posts talking about putting screen in front of the radiator but never anything that would suggest this could have some drawback.
What-say some of the A/C experts here on the board. Window screen okay or clean them bugs?
