Building a "tool box"...
Anybody familiar with this OBD tool?
3d scanner/printer
After many years of service, I have came to the conclusion my Knaack box is just not big enough. I believe its a #79, about 24"x24"x60"... construction site toolbox. The box is mounted on a small trailer, I tow it cross country. I believe the frame was a small compressor or generator in a previous life. I placed a set of Dana 60 axle tubes (chopped the center section out) under it for an axle to give me an HD axle (big bearings) with 8 lugs. The deck is about 40"x72", so the box doesn't actually fill it out.
I got a line on some 1/8" and 1/16" aluminum diamond plate (fairly big sheets, as in 30"x60"). Now, I know 1/8" would probably be fine structurally with some bracing, but 1/16" is way to light. I was thinking of building a box to the dimensions of the deck. I was thinking of using 1/2" outdoor plywood to give some rigidity, and then "covering" the wood box with the diamond plate. Probably do either a single hinged lid on one side or two lids hinged in the center (opening towards the ends).
I was figuring this would yield a box around 40" wide x 30" tall x 72" long, significantly larger than what I currently have... and still fairly protected from theft (I never leave the trailer sit anywhere alone, its at most in a hotel parking lot).
Sound like a good idea? Or should I continue to look for a larger Knaack?
I don't think using wood is a good idea if it's going to be exposed to the weather. It'll look awful after a short time, even if the wood is only internal structure (somehow it always accumulates moisture, doesn't it?). And it seems like the hinges will tear up the wood with repeated use.
If I were doing it I'd probably use steel sheet, either 3/32 or 1/8" (or a combination). Easier to weld, harder to break in to. And no need for a wooden substructure.
Going to be a lot of work...
Ryan
