Competition building driveshaft loops for pulling
Competition How much can the stock driveline take?
Competition Trading Cards
When you guys build and install drive shaft loops, how do you make them articulate with the driveline. My truck is a daily driver, but due to wanting to pull I plan on installing loops. Initially I was just going to put one at the rear/front of each driveshaft at the differential. After watching a Mod (gasser) truck last night break one at the carrier, I'd like to build something that will take a bit more worry out of it. One truck I saw had the loop at the rear differential tied into the ladder bars?! Any advice before I go nuts with some pipe, a welder and some steel?
Josh
Josh, take a look at pictures #10 and #11 in this album, these are Chris Suttons he did an excellent job, and yes on his daily work truck :D
Click Here
Hope you don't mind Chris.
BBD
Hey thanks guys. Now I see how they set it up to move with the axle. Last night I think most of the suspensions were so fixed that articulation was not a concern.
Josh
