Built-in trailer brakes?
4-Corner air suspension?
Won't regen
in my manual, there are some ram1500 packages that had trailer brakes already installed from the factory.
Anyone know whether they’re good or is aftermarket (UHaul/Reese, etc) better?
I asked at the local dealership if there was a retrofit dealer install FCA OEM kit that would sit right in the dashboard, but, not at that time. (February, with a possibility of a March release)
Reason? Tidy! Right in the dashboard instead of looking like an afterthought.
I have the Integrated Brake Controller on my wifes 2019 1500 and it works great. I don't think there would be a difference between a gasser and a diesel. I compared my wifes truck controller with the one on my 2017 Ram 5500 and my wifes actually gave stronger results.
Hope this helps.
Cheers, Ron
For those interested, I talked to my Ram dealer’s service Dept this evening.
Part # 82215040AC for my application (looked up via VIN) and just under $700 installed. Yes, seems pricey compared to a UHaul install, but, tidy.
Will likely be doing before year’s end.
There was also a part number I found that ended “...AB”, but it turned out not correct.
