Well I finally got all the parts together to build some control arms. I made them 1/4" longer then stock to give more tire clearance when I have the 33x12. 5x16. 5 tires on and to make up for the 2" leveling kit. I hope to install them tomorrow when the paint is dry. Some of the bushings on my stock ones were coming loose from the arms back a few years so I tack welded them but now both shells are cracked clear across in one upper arm.
For the new arms I used 1. 5"x2. 5"x1/8" tube with 2. 5" and 2" Johnny Joints at the axle end and standard poly "T" bushings at the frame end. All but the upper frame end joints are greasable. They cost me about $290 including the paint but not including the two hole saws I had to buy. Will be interesting to see how they work.
